Zon activity time
Hi!
I have made a flow that will save my garden from roe deers!
I’m using zon activity, a hue motion sensor, to trigger my sprinklers to scare them away.
Since I don’t want birds to trigger the flow I’w set the trigger to be “zone activ for…”
My problem is that the shortest activity time I can set i one minute and by then my tulips are gone…
So, is there a way to do this with a shorter activity time?
Best regards
Oskar
Not with “Zone active for…”, 1 Minute is the shortest time.
Btw, in my opinion Zone Activation makes only sense, if you have a zone with multiple sensors (e.g. motion sensors, door/window sensors).
But of course, Zone Activation can also be used with only one sensor.
This is a really simple flow:
If…
– The motion alarm was triggered
And…
– whatever (time, presence, etc.)
Then…
– Turn sprinkler on
– Turn sprinkler off with delay of 5 s
But of course, there are several possible solutions.
What I don’t understand!?
What is the relationship between Zone Activation and birds? If a zone or a sensor is triggered has something todo with the sensitivity, orientation and the type of a sensor.
Do I understand this wrong?
Thanx for your anser!
The thing is that I dont want some thing fast, as a bird flying by, to trigger The sprinkler.
Just some thing that stays in The zone for 20sec. for instance some one eating my tulips!
As I understand it I can’t get a “PRESENCE FOR…”
comand, just a delay then another check if there is some thing present.
Or am I wrong?
Best regards
Oskar
Almost all PIR’s have a 1 min. alarm state (mostly to save battery life)
The Aqara PIR can be modified, so the minimum alarm state can be brought back to minimal 5secs.
Then you could create a flow using timers and delays
The card in the If… section is in any case only a momentary trigger. So it’s not possible to set a time range or something similar.
For the Birds you have to change the flow, you have to use a timer, and you have to change the standard settings of the Hue Outdoor Motion Sensor.
Flow 1
If…
And…
– Timer “Birds” is not running
Then…
– Start Timer “Birds” with 20 s
Flow 2
If…
– Timer “Bird” has expired
And…
– The motion alarm is on
Then…
– Turn sprinkler on
Important: You have to change the parameter “Time until motion alarm is reset (s)” of the Hue Outdoor Motion Sensor into less than 20 s.
If the Hue Outdoor Motion Sensor is paired directly to Homey, you can change the alarm reset time between 1 - 86400 s. I don’t know if it is also possible when the OMS is paired with the Hue bridge.
Can u name some (as u seem to know for sure) of those PIR’s ?
@Rocodamelshekima only:
Look, funny kid with the impossible name,
I have no clue what did to you, but could you stop scanning for my “errors” only, kind of pathetic nerdy and schoolteacher like? And then try to make yourself look as the smartest of the universe? Or do you just like to troll around here? Nothing better to do?
Thank you.
I’m just trying to help people here.
I’m not gonna start and end each and every post with “as far as I know” en end it with “correct me if I’m wrong”
To me that’s obvious.
Not scanning ur errors. Just curious what PIR’s there is besides the Aqara that have that limit. And if u do a lot of replies to help, u also get some questions. It was just a question to somebody who seems to know for sure there is lots of them. Just wondering.
Ow and am not a kid anymore.
