Zigbee radiateur ACOVA ALCANTRA
Bonjour
Sous jeedom, je pouvais intégrer ces radiateurs, en ajoutant le script cf ci apres.
Savez vous s’il est possible de faire la meme chose ?
Good morning
Under jeedom, I could integrate these radiators, by adding the script cf below.
Do you know if it is possible to do the same?
  "name": "ACOVA Alcantara2",
  "ref" : "ALCANTARA2 D1.00P1.01Z1.00",
  "type": "Chauffage",
  "buylink": "https://www.leroymerlin.fr/produits/chauffage-plomberie/chauffage-electrique/radiateur-electrique/radiateur-a-inertie/radiateur-electrique-connecte-a-inertie-fluide-1000w-acova-alcantara2-horizontal-82646764.html",
  "remark": "",
  "documentation": "https://acova.fr/sites/default/files/PIM/documents/Notice_utilisation_Alcantara_2.pdf",
  "reset": "Appui de 5 secondes sur le bouton Mode puis 2 secondes sur le bouton -",
  "pairing": "Appui de 5 secondes sur le bouton Mode puis 2 secondes sur le bouton +",
  "commands": [
      "name": "Local_temp",
      "type": "info",
      "subtype": "numeric",
      "generic_type": "THERMOSTAT_TEMPERATURE",
      "isVisible": 1,
      "isHistorized": 1,
      "logicalId": "1::513::0",
      "unite" : "°C",
      "configuration" : {
        "calculValueOffset":"#value# / 100"
      "name": "Occupancy",
      "type": "info",
      "subtype": "string",
      "isVisible": 1,
      "isHistorized": 0,
      "logicalId": "1::513::2"
      "name": "Occupancy Sensing",
      "type": "info",
      "isVisible": 1,
      "isHistorized": 0,
      "logicalId": "2::1030::0"
      "name": "system_mode",
      "type": "info",
      "isVisible": 1,
      "isHistorized": 0,
      "logicalId": "1::513::28"
      "name": "running_mode",
      "type": "info",
      "isVisible": 1,
      "isHistorized": 0,
      "logicalId": "1::513::30"
      "name": "running_state",
      "type": "info",
      "isVisible": 1,
      "isHistorized": 1,
      "logicalId": "1::513::41"
      "name": "occupied_heating_setpoint",
      "type": "info",
      "generic_type": "THERMOSTAT_SETPOINT",
      "isVisible": 0,
      "isHistorized": 0,
      "logicalId": "1::513::18",
      "unite" : "°C",
      "configuration" : {
      "name": "Thermostat occupied_heating",
      "type": "action",
      "subtype": "slider",
      "isVisible": 1,
      "isHistorized": 1,
      "unite" : "°C",
      "value": "occupied_heating_setpoint",
      "logicalId": "attributes::1::in::513::18::#slider#*100",
      "generic_type" : "THERMOSTAT_SET_SETPOINT",
      "configuration" : {
        "minValue":"7",
        "maxValue":"28"
      "template" : {
        "dashboard" : "button",
        "mobile" : "button"
      "name": "unoccupied_heating_setpoint",
      "type": "info",
      "isVisible": 0,
      "isHistorized": 0,
      "logicalId": "1::513::17",
      "unite" : "°C",
      "configuration" : {
      "name": "Thermostat unoccupied_heating",
      "type": "action",
      "isVisible": 0,
      "isHistorized": 0,
      "unite" : "°C",
      "value": "unoccupied_heating_setpoint",
      "logicalId": "attributes::1::in::513::17::#slider#*100",
      "configuration" : {
        "minValue":"7",
        "maxValue":"28"
      "template" : {
        "mobile" : "button"
      "name": "occupied_cooling_setpoint",
        "type": "info",
      "isVisible": 0,
      "isHistorized": 0,
      "logicalId": "1::513::20",
      "unite" : "°C",
      "configuration" : {
      "name": "Thermostat occupied_cooling",
      "type": "action",
      "isVisible": 0,
      "isHistorized": 0,
      "unite" : "°C",
      "value": "occupied_cooling_setpoint",
      "logicalId": "attributes::1::in::513::20::#slider#*100",
      "configuration" : {
        "minValue":"7",
        "maxValue":"28"
      "template" : {
        "mobile" : "button"
do you have an idea ?
kings regards
