When I test it, it works, but in practice, the light doesn’t turn on.
Who can help?
Thx Paul
The flow should work.
You can add a timeline notification after the If card to see if the card is triggered.
When you test from the WHEN card by control-click the card. No need for the blue arrow card.
This is because you “impersonate” the trigger when testing a flow.
We can’t test a trigger.
This means the trigger doesn’t work. To check it:
First create the simplest flow possible:
When..
motion detected
Then..
send push notification to yourself
When there’s no push notification, the motion sensor doesn’t work, or its connection is flaky
Ja, op de statuspagina van de sensor geeft hij beweging aan.
Does the motion detector turn off again? I have Neo Coolcam motion detectors, and occasionally it happens that it stays “on”. The result is that no movement is detected.
