I am looking for a keypad that has a RFID tag reader and also accepts a 4-6 digit code.
I want to use this for setting/disarming the alarm built with Homey.
I also want to be able to see in Homey which person or which tag/code was used to disarm the alarm.
The Benext is not available anymore. Does anyone have any suggestions?
That one actually is the same as the Benext (rebranded??).
I think the Zipato keypad also is not available at the moment/anymore.
In Robbshop it even says EOL.
@Sylv1
Unfortunately I cannot order the Zipato keypad at the store you bought yours. It does not ship to the Netherlands. And because it probably is End Of Line I think it is better not to buy, one just in case I get problems in the next 2 years. I’m not sure w.r.t. warranty if they can fix it or ship a new one if it can’t be fixed.
That correct, I only use RFID keyfob, smartcards or stickers to disarm the alarm. You could use the 3 buttons to enter a pincode, or you could replace teh RFID reader below the screen for a numeriek keypad. Both is not possible.
If you don’t want a DIY Solder/program solution, look at this
Just combine two cheap parts (available from anywhere) and you got a RFID/Keypad zwave solution.
I have talked to a Robbshop employee about that solution, but, using the Firbaro smart implant, it only can set the alarm and disarm the alarm when the code/tag is accepted
It does not share the code or RFID tag ID with Homey, so I cannot determine who disarmed the alarm.
