"When dim level set to by physical switch" card
An ability to differentiate between when a device is turned on by physical switch and by homey.
Use case 1
I will use this in my bathroom, where only the main light will operate when its dim level is less than 90% - however when it is manually operated, and dim level is set to above 90%, all other lights in the room will activate (better for cleaning).
However we need to differentiate between physical dimmer and din level set by homey, because the motion sensor and lux sensor may demand more than 90% dim level to keep lux at a desired level, and in this “automated” operating mode we do not want to trigger the extra light we use when cleaning (harsh lighting).
What can be other use cases for these “turned on by physical switch” and “dim to level by physical switch” cards?
