Weishaupt integration with Homey
Good morning
I have created a Weishaupt (wemportal) integration into Homey.
For now it is possible to read multiple temperatures from the system but using the flows, temperatures can be set as well.
Any feedback is welcome :slight_smile:
Source code can be found GitHub - reyntjensw/Homey-Wemportal
Hi there.
I have an older Weishaupt heater. What is needed for it to be able to connect to this/the internet?
Hi
I think you need to check if there is a compatible model.
I know that there is also a license fee for using the system.
I would suggest contacting you plumber, he will be able to help you.
Wouter
Hi.
I recently installed the app but can’t get it to work. I keep getting this error: (Type error: cannot read properties of undefined (reading ‘ModuleIndex’))
I did put my user and pass as needed.
Txs for your help
Luc
Hi Luc
What type of system do you have?
Is it a heatpump or a boiler?
Hi. It’s a gas boiler for central heating.
Can you help?
Txs
Luc
Hi @Luke101
I’m fixing a bug in the system which might cause your issue.
When the new version is present I’ll let you know.
Hi Luke the new version is out, can you please try again?
Hi Wouter,
I have a Weishaupt biblock heatpump and would like to write my own control algorithm to optimise the pumps performance. I have not decided on a platform yet but your work for homey looks very interesting for my purposes :slight_smile:
I can read and write through the WEM portal but do I understand correctly that this integration only allows writing to parameters exposed through the (very limited) Weishaupt app?
Is it also correct that I need at least v5 firmware on my heat pump?
Many thanks in advance,
Geert
Hi Geert
Thanks for your kind words.
With Weishaupt, the issue is that the api is not public, so you can have a hard time figuring out the api calls. There are other open source projects for Weishaupt where I got my inspiration.
Regarding to the values, you are limited (as far as I know) to the values from the website or the app.
You can try to decode the app and retrieve the api calls from there.
Regarding firmware versions, I am not aware of what the requirements are there.
Hi reyntjensw,
since yesterday I have a BiBloc heat pump from Weishaupt and now I try to get the App running.
It was possible to install the heat pump but now I get the message : Gerät nicht verfügbar
Error retrieving data (TypeError: Cannot read properties of undefined (reading ‘ModuleIndex’))
There is always a red exclamation mark in the icon.
It would be very nice if you have a hint for me .
best regards
Marcel
Hi Marcel
I made the app for a gas heating, I would assume that for a heat pump the results will be different hence why this is causing issues.
The only suggestion I could give you is to jump into the code and create a new driver for the heat pumps.
The issue is that the documentation for the api does not exist, and every call needs to be reverse engineered. Which is very time consuming.
Hey,
Thanks for your App!
Unfortunately we got the error Error retrieving data (TypeError:
Cannot read properties of undefined (reading ‘Modulelndex’))
We have received the gas heating model WTC-GW at the beginning of the year.
Do you know a solution for this problem?
I unfortunately get the error Error retrieving data (TypeError: Cannot read properties of undefined (reading ‘outdoor’))
We have a WP-LS-13 system.
Hopefully it can be fix
Hello
I installed your app for the Weishaupt heating today,
but I always get an error. During installation, my heating is recognized, but then an error immediately appears:
Error retrieving data (TypeError: Cannot read properties of null (reading ‘split’))
any solution ?
Thomas
Hallo,
App installieren kein Problem. Nach dem Login wird der Brenner auch erkannt.
Danach werden aber keine Daten angezeigt.
Schein keine Verbindung zu Brenner aufbauen zu können.
Vielleicht gibts da ja ein Lösung dafür.
Danke
Diagnosebericht →
bf932be8-b56e-482b-bc8f-b7def80a3e82
No News?
