Thx for answering.
I finally made it
Atually the problem was about the ID of the charger. As someone said above, you have to take the serial number in the wallbox app and not the id!
Could it be possible to have the current Power or A displayed by the Wallbox?
Thx!
Who can help me out.
Just install the wallbox app in combination with my wallbox Pulsar Plus. After login with my wallbox account, the device is visible at devices Page in homey. After a few Seconds the device is offline. Strange enough the device sometimes comes online and after a few seconds its offline again.
offline
Good afternoon all.
I’m trying to set-up a flow that triggers a certain amount of questions / actions in Homey once I plug in a car into my Wallbox. The only issue: I put my Wallbox on autolock as I don’t want it to automatically start charging my (or anyone’s) car when it’s plugged in.
If a car is plugged in, I want to get a question - in which I confirm that I plugged in a certain car, after which PBTH starts searching for the cheapest X hours and then, once that moment has arrived - it should unlock and start the Wallbox.
My issue specifically is that Homey is not recognising that a car is plugged into the Wallbox if it is put on lock. Meaning my flow isn’t being kicked off. So; my question: How can I let Homey know that a car has been plugged into the Wallbox - while making sure that the Wallbox is not automatically starting to charge?
The only ugly solution I could think of is to remove the autolock, and everything a car is plugged in and starts charging, making it stop charging immediately and then kicking off the flow. But that’s not a very elegant solution…
Thank you all in advance!
Need help with solar and EV charging automation
I have a photovoltaic system (Solax) and an electric vehicle, Mercedes EQE. When I arrive home with my car, I plug it into my PulsarPlus charging station, and I want the car to start charging only when there is excess energy (overflow) from the solar panels. Until that happens, I don’t want the car to charge.
For example, if the car’s battery is below 80%, I want it to start charging until it reaches 80%, but only when there is overflow from the solar panels.
I couldn’t find any option in the Wallbox Charger app that shows the current charging level of the car in Homey.
Can anyone suggest how to set this up on Homey? I would like to automate the charging process based on the availability of excess solar energy.
The wallbox can’t know the charging level of your car.
That’s only possible reading the car data. So you would need access to your car data with a Homey app.
I’m not sure if i’m in the right topic.
But the Wallbox of Volvo is normally from Wallbox. Can it also with with this app for Homey ?
Br
Jan
