Wallbox Pulsar plus charger lock/unlock pause/resume
cool, no thanks I’m doing this to help and nothing else.
tell me when you update that I check if I haven’t made any mistakes
Hi, is it possible to add more Then flow cards - like changing AMPs?
Is there a way to support developer with “coffee”? :slight_smile:
@Sen-Sai would it be possible to add a tag for the current authenticated user of the charger? I am using this to divide charging costs between different users, so i would like to know the current user of the charger. Thanks :slight_smile:
Hi, I’m currently working on that, because it is a much requested feature. Hopefully I can release it this week.
So far no coffee support possibilities, but I’ve gotten this question multiple times so maybe I’ll add a button soon. But the thought is already highly appreciated.
New Homey arrived, this app was the first that I did install :wink:
First device went well, but when I chose to install a second device to make a second instance with different credentials it tells me “no new device found”.
So, our usecase is to use a Wallbox instance dependent on the car to be charged (business/private).
Hope you can help me out.
