VThermo sensor compatibility
Hi, I installed VThermo app and it seems really a wonderful & useful app for what it promises: “Add a virtual thermostat to a zone with a temperature sensor and it will turn on / off heaters in the same zone”.
I use Sonoff devices (Basic, POW, 4CH Pro, TH16 etc) and they are working good in my environment, using flows. I tried to use them with VThermo but they don’t work:
1st configuration:
  • Sonoff TH16 as themperature sensor and switch of an electric heater
    2nd configuration:
  • Sonoff Basic to switch the electric heater; Sonoff TH16 as themperature sensor
I configured the switch as attached to an heater; defined the zone and applied VThermo to the zone, but VThermo doesn’t see the sensor (the current temperature is not reported) and doesn’t switch on/off the switch.I didn’t do any flows because VThermo (I think) would have all done by itself.
Do I anything wrong, or maybe is it a problem of compatibility with the Sonoff devices?
Is there a way to see an events log and control what’s happening?
Many thanks in advance…
For VThermo to see a sensor it must be a sensor with measure_temperature - capability.
In the latest version also thermostats can be used, if the “Temperature from thermostat” is checked in advanced settings, and the thermostat has a measure_temperature - capability.
You can check the capabilities from https://developer.athom.com/tools/devices. Search for the device and look for the measure_temperature capability.
The VThermo starts working as soon as you set the setpoint / target temperature.
