Variable in a coutdowntimer
Can somebody tell me why i can´t use a variable in a countdown timer?.
When i use the var the timer will not start. it will only start if i type a number
It works with Chronograph timers;
I just installed Countdown, and it works as well, even with 3.4 as variable value:
Maybe you used a comma instead of a decimal dot?
Thanks i will try that, the timer is set to 300. And so was the varible
Hilsen/Best Regards
Claus Jacobsen
man. 12. jan. 2026, 17.58 skrev :netherlands: Homey Pro 2026 SE 2x Homey Pro 2019 Classic <notifications@athom.discoursemail.com>:
If i do that it will not start either. It comes with an error “invalid duration”
Hilsen/Best Regards
Claus Jacobsen
man. 12. jan. 2026, 18.45 skrev Claus Jacobsen <forumvej16@gmail.com>:
Maybe 60 seconds is the max value. You could try 5 minutes instead.
If i type 300 instead, it is working
Hilsen/Best Regards
Claus Jacobsen
man. 12. jan. 2026, 19.27 skrev SunBeech <notifications@athom.discoursemail.com>:
Sorry my bad. Ive used the wrong var. Thanks you for your feedback
Hilsen/Best Regards
Claus Jacobsen
man. 12. jan. 2026, 19.28 skrev Claus Jacobsen <forumvej16@gmail.com>:
Ah great that you solved it!
Off-topic: when you respond via e-mail, additional information is added to the post. Including your mail signature and e-mail address of the mail you are responding to. Your own e-mail address is sometimes visible, like in the above post. Not sure whether you want to remove that info.
Thanks
Hilsen/Best Regards
Claus Jacobsen
man. 12. jan. 2026, 19.47 skrev SunBeech <notifications@athom.discoursemail.com>:
