Homey uses 2 Watt with LED ring off up to ~5 Watt, with the default LED ring at 100%
Maybe somewhat more when sending and on heavy load.
You could use a USB powerbank as el cheapo UPS, if that powerbank does not cut the power when switching between loading and not.
Be warned these are often not made for continue loading and defective batteries can catch fire.
