On Truenas scale / Hexos there is an update version 1.3.3_1.3.4 available. When updating SHS from 1.2.19 to this 1.3.3_1.3.4 version I get the following error.
[EFAULT] Failed to render compose templates: Traceback (most recent call last): File “/usr/bin/apps_render_app”, line 33, in sys.exit(load_entry_point(‘apps-validation==0.1’, ‘console_scripts’, ‘apps_render_app’)()) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File “/usr/lib/python3/dist-packages/catalog_templating/scripts/render_compose.py”, line 48, in main render_templates_from_path(args.path, args.values) File “/usr/lib/python3/dist-packages/catalog_templating/scripts/render_compose.py”, line 19, in render_templates_from_path rendered_data = render_templates( ^^^^^^^^^^^^^^^^^ File “/usr/lib/python3/dist-packages/catalog_templating/render.py”, line 31, in render_templates rendered_templates[i.name] = env.get_template(i.name).render( ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File “/usr/lib/python3/dist-packages/jinja2/environment.py”, line 1301, in render self.environment.handle_exception() File “/usr/lib/python3/dist-packages/jinja2/environment.py”, line 936, in handle_exception raise rewrite_traceback_stack(source=source) File “/mnt/.ix-apps/app_configs/homey-shs/versions/1.3.4/templates/docker-compose.yaml”, line 30, in top-level template code {% set tpl = ix_lib.base.render.Render(values) %} ^^^^^^^^^^^^^^^^^^^^^^^^^ File “/mnt/.ix-apps/app_configs/homey-shs/versions/1.3.4/templates/library/base_v2_2_2/render.py”, line 34, in _init_ self._original_values: dict = copy.deepcopy(self.values) ^^^^^^^^^^^^^^^^^^^^^^^^^^ File “/usr/lib/python3.11/copy.py”, line 146, in deepcopy y = copier(x, memo) ^^^^^^^^^^^^^^^ File “/usr/lib/python3.11/copy.py”, line 231, in _deepcopy_dict y[deepcopy(key, memo)] = deepcopy(value, memo) ^^^^^^^^^^^^^^^^^^^^^ File “/usr/lib/python3.11/copy.py”, line 146, in deepcopy y = copier(x, memo) ^^^^^^^^^^^^^^^ File “/usr/lib/python3.11/copy.py”, line 231, in _deepcopy_dict y[deepcopy(key, memo)] = deepcopy(value, memo) ^^^^^^^^^^^^^^^^^^^^^ File “/usr/lib/python3.11/copy.py”, line 161, in deepcopy rv = reductor(4) ^^^^^^^^^^^ TypeError: cannot pickle ‘Undefined’ object
I guess I’ll wait until the next update for this update…
