Unknown Zigbee Node Removal
Hi Guys,
Does anyone have unknown zigbee node? I have several, but there is no way to remove them since these are can’t be found in the GUI. Some of the end devices can’t be repaired and I think it can be one of the reasons.
The 60:a4:23 device results to Silicon Labs in the OUI lookup. Several devices use these modules: some older Tuya devices, IKEA devices and likely many others. The 54:ef:44 device results to LUMI (Aqara) in the OUI lookup. You should check which devices are missing in your devices list and reset these devices and re-add them. It will return “Device already added” but maybe you can remove them afterwards.
