I have several LSC GU 10 Spotlights. In the Tuya app (Android), I can choose both color and white.
In the Homey Pro, there’s no card where I can select between color and white light.
Is there a solution for this?
I’m assuming that your lamp is working in Homey. In some cases with zigbee modules, colormodes are not shown in Homey, and a possible solution that has worked for me in the past is executing an interview of the device:
In Homey developer tools, under zigbee, search for the device, and execute an interview. After that, the capabilities of the device are shown correctly.,
Hi Thunder issue solved
How did you solve the issue?
There was no value:
| light_temperature | Kleurtemperatuur | number | 1, |
I set the value to 0,01 & after executing, the issue was solves
I will do this with all Tuya lights
