[TUTORIAL] Make shortcuts/ widgets for iOS
This tutorial has been moved to Klik hier
To quickly use the command I use in the command app, you can download it via the link below
Link file: Click Here
done exactly as described. only he does nothing at all. Token taken from the webhook. is something missing in the description?
Modbreak. Post is very offtopic and therefor deleted. If u have any problems with that please contact a moderator via PM. Post will vanish in a couple of days.
it is important that you make sure your phone does not capitalize when entering the event name. Have you also put the token from the webhook manager app in the link?
had everything in lower case. unfortunately. it succeeded via HTTP request
Hoi Ruud, ook ik heb eigenlijk alles gedaan volgens je film op YouTube en toch start de flow niet. Ik weet niet waar de fout zit.
