Turn on a light without setting a color or level in a mood
Is there an easy way to just turn on a number of lights (but not all) in a room without setting the color or the sensitivity so that they return to the last scene set?
Steve
Yes, tap the Lights button at the top of the zone. You can then turn individual lights on or off.
If you want to regularly turn on/off a custom group of lights, you might want to consider using the ‘Multiple’ lights widget that you can place on a dashboard or your home screen. It allows you to select which lights you want to include and switch them on/off with a single toggle.
Many thanks
