TT Lock integration
Anyone that has done the TT lock integration into Homey and willing to share the coding?
I have been looking at this link and not beeing able to follow it to the end.
any help would be appreciated
The Matter Hub is now available for TT Lock - I’m using the one from SImpled and testing at the moment.
Darrell
Did you integrate the Wi-Fi locks via the Matter ttlock hub and is it recognized by Homey? Can you post some screenshots? Thanks.
Hi Giovannni
Sorry for late reply.
Yes, I have sort of got the integration working, the G6 Hub from Simpled connects to Homey without issue but there are still some bugs I’m chasing developers for. The most annoying one which they disagree with is that the Hub auto relocks after 1 minute. They claim it is down to Homey Pro but there is no option to set s timer and a Hub should just be a gateway, it should not override the settings in the lock i.e. I have auto re-lock turned off but 1 minute after unlocking via the G6 Hub, you see activity on the hib and the door re-locks.
The commands it presents to Homey Pro are as follows:
When:
And:
And:
I’ve yet to work out what turn on and turn off do.
In prinicpal it works, if I go out and forget the door, it always locks which is great but I wanted to use presence to unlock when arrive home and in its current state, it does unlock but unless you break the sound barrier running from car to back door, it has re-locked the door!!!
I have another post on the forum which is looking into the parameters that Homey sees from the hub.
Hope that helps
Darrell
Hi Darrell
witch TTLock have you exactly?
I have this one, there is not possible to stop lock after 1 minute.
Hi, what you mean is the door latch settings (which keep the latch locked until you enter the door). I don’t know if they can be set above a certain value. I can’t check right now because I’m not connected to the lock via Bluetooth. Are you planning on integrating the Bluetooth locks into Homey as well?
And what about the lock icon status?
I use this one, the EF Series
Hi
I’m using Bluetooth only for local attachment when at home and the TTLock App. For Homey Pro, I’m using the G6 Matter Gateway. The setting I was referring to is this one in the TTLock App that allows you to set auto re lock to off or after a specific delay. This works fine but the current issue is, even if this is off, when using Homey to send an Unlock via the G6 Hub, the Hub tells the door to re lock after 1 minute and there doesnt seem to be any way to override this.
Are you using the G6 Gateway?
That‘s the same like mine
No, i have the G2
Ahh ok, not sure how G2 would link to Homey - the G6 is Matter so links with no App but just gives the basic functions.
I had no intention of adding Homey. I haven’t installed the G2 yet either.
But if it works with the G6 and the features that are relevant to me work, then I might buy the G6.
Let’s see what else you can tell us. :wink:
if you look at my post a little further back, I’ve shown the functions trhat are available via the G6 Hub
Darrell
sorry, I thought it was the switchbot topic
Hi, I have just received my G6 matter gateway for use with my Simpled door lock. I have connected the G6 to my 2.4ghz wifi (weak signal) and connected it to Homey Pro via the matter interface.
I can now see the triggers in Homey but cannot get it to do anything.
I am after an alert if the door is opened / unlocked etc.. has anyone managed to get this working?
Same here. It has very weak signal to the doorlock even from 1,5 meter distance. Integration doesn’t work properly. It connects but the lock shows unlocked all the time. Making flows on unlock/lock status is useless as it doesn’t show it’s current state. I was using a aquara doorsensor to show door open or closed and flows to send notifications on it. This works flawless.
Hello. I’m a long time HomeKit user and a brand new Homey owner. I’m looking forward to automating everything by flows. I just got installed new windows and doors, and because of the mekanism to lift the handle before locking I am very interested in this product. I haven’t heard of any other. So I will be watching here and possible buying one if the issues talked about in this thread are fixed.
