I am trying to create an app for my Aflamo fire place, it has IR control, and managed to catch the codes for it. I used the example found here on the community (IR Device) but it fails to run. I can install the app, add a devices, but it gets stuck with a spinning circle in the device icon.
When I use the CLI run command, it shows the following error.
2023-07-24T11:36:52.415Z [log] [MyApp] MyApp has been initialized
2023-07-24T11:36:52.423Z [err] [ManagerDrivers] Error Initializing Driver aflamo: /app/drivers/aflamo/signal.js:2
SyntaxError: Invalid or unexpected token
at Object.compileFunction (node:vm:360:18)
at wrapSafe (node:internal/modules/cjs/loader:1124:15)
at Module._compile (node:internal/modules/cjs/loader:1160:27)
at Object.Module._extensions..js (node:internal/modules/cjs/loader:1250:10)
at Module.load (node:internal/modules/cjs/loader:1074:32)
at Function.Module._load (node:internal/modules/cjs/loader:909:12)
at Module.require (node:internal/modules/cjs/loader:1098:19)
at Module.homeyRequire [as require] (/node_modules/@athombv/homey-apps-sdk-v3/index.js:12:19)
at require (node:internal/modules/cjs/helpers:108:18)
at Object.<anonymous> (/app/drivers/aflamo/driver.js:2:18)
signal.js
const { RFSignal } = require('homey-rfdriver');
class MySignal extends RFSignal {
static FREQUENCY = 'ir';
static ID = 'aflamo';
module.exports = MySignal;
driver.js
const { RFDriver } = require('homey-rfdriver');
const MySignal = require('./signal.js');
class MyDriver extends RFDriver {
static SIGNAL = MySignal;
module.exports = MyDriver;
This is my first go with making an app for Homey pro 2023, not much experience with node/java, any help would be welcome ![]()
