luvis
May 2, 2019, 9:05am
#1
I’m wondering if this is possible some how, anyone have any ideas?
luvis
May 5, 2019, 7:43am
#2
I assume that either my question is poorly formed or no one knows… What I want to achieve is the possibility to trigger a signal on a muted iphone and find it’s location, through homey. If there’s any other way to do this, please let me know if you know.
Not a answer to your question, just to let you know that you can edit your own post, instead of making a new reply
viix
May 6, 2019, 3:33am
#4
Is it even possible to trigger “find my phone” outside of an apple devices or the icloud website? Especially if you are using 2FA?
There is a client for it in Python. It would be possible to create an app for that. Problem is with 2FA, you have to interact with it quite often.
.. image:: https://travis-ci.org/picklepete/pyicloud.svg?branch=master
:alt: Check out our test status at https://travis-ci.org/picklepete/pyicloud
:target: https://travis-ci.org/picklepete/pyicloud
.. image:: https://badges.gitter.im/Join%20Chat.svg
:alt: Join the chat at https://gitter.im/picklepete/pyicloud
:target: https://gitter.im/picklepete/pyicloud?utm_source=badge&utm_medium=badge&utm_campaign=pr-badge&utm_content=badge
PyiCloud is a module which allows pythonistas to interact with iCloud webservices. It's powered by the fantastic `requests <https://github.com/kennethreitz/requests>`_ HTTP library.
At its core, PyiCloud connects to iCloud using your username and password, then performs calendar and iPhone queries against their API.
Authentication
Authentication without using a saved password is as simple as passing your username and password to the ``PyiCloudService`` class:
>>> from pyicloud import PyiCloudService
This file has been truncated. show original
luvis
May 6, 2019, 6:34am
#6
I see, yeah that makes sense. it’s unfortunate that there’s no sms-activation like there is for most Android similar systems… that would have solved everything. I’m not savvy enough to create an app I’m afraid…
