Nope. Just a timer for 30 minutes to check again if the power<100 and then turn the plug off.
There we go! I found a way of triggering my flows with the power-tag
I just dragged the “Devices” to my “When”, (a sensors value changed - Power) and then linked that to “better logic” in my “Then” column (set number variable). That way i got my self a variable to play with
I only have one device that has the ability to measure watt. the way it works now, i guess, is that if i had more power plugs that can meaure watt - them as well will trigger the flow?
@Rocodamelshekima do you know if this is correct and of it is possible to limit this to just one perticular device?
Correct. But u can also check on zone in the AND colom with a logic card.
Ah, smart. added a name is exactly to the AND
worked great, Thx @Rocodamelshekima
