Is there a way to toggle all of the lights on or off in a room with one flow card instead of if/then logic or groups?
I ran into the same thing when I started. The simplest way I found was to group the lights for the room first, then use that one group in a flow, rather than adding each light separately. It keeps the flow much tidier, and you can still turn one light on or off by itself when you need to.
HAve a look at the app from Jamie Peak < groep > for advanced groups etc.
Ummmm:
I created a Homeyscript to do it so I don’t have to rely on groups. It toggles the lights on or off and sets the brightness and color temperature to a specific level based on variables
Any additions or comments to improve it would be very welcome
const roomName = String(args[0] ?? '').trim();
if (!roomName) {
throw new Error('Pass a Homey zone name, such as Dining Room.');
const [zones, devices] = await Promise.all([
Homey.zones.getZones(),
Homey.devices.getDevices(),
const matchingZones = Object.values(zones).filter(
zone => zone.name.toLowerCase() === roomName.toLowerCase()
if (matchingZones.length === 0) {
throw new Error(`No Homey zone named "${roomName}".`);
if (matchingZones.length > 1) {
throw new Error(`More than one Homey zone is named "${roomName}".`);
const [zone] = matchingZones;
const lights = Object.values(devices).filter(device =>
device.zone === zone.id &&
(device.class === 'light' || device.virtualClass === 'light') &&
device.available !== false &&
typeof device.capabilitiesObj?.onoff?.value === 'boolean'
if (lights.length === 0) {
throw new Error(`No available lights with a known on/off state in "${zone.name}".`);
const onCount = lights.filter(light => light.capabilitiesObj.onoff.value).length;
const turnOn = onCount * 2 < lights.length;
log(`${zone.name}: ${onCount}/${lights.length} on. Setting room ${turnOn ? 'ON' : 'OFF'}.`);
function canSetBrightness(light) {
const driver = light.driverId ?? '';
const app = light.ownerUri ?? '';
const isShelly = /shelly/i.test(driver) || /shelly/i.test(app) || /^shelly\b/i.test(light.name);
return !isShelly && light.capabilities.includes('dim');
function readPercent(setting, name) {
const value = setting?.value;
if (Number.isFinite(value) && value >= 0 && value <= 100) return value / 100;
log(`Warning: ${name} must be a number from 0 to 100.`);
let temperature;
let brightness;
const hasTemperatureLights = lights.some(light => light.capabilities.includes('light_temperature'));
const hasBrightnessLights = lights.some(canSetBrightness);
if (turnOn && (hasTemperatureLights || hasBrightnessLights)) {
try {
const variables = Object.values(await Homey.logic.getVariables());
if (hasTemperatureLights) {
const color = variables.find(variable => variable.name === 'LightColor')
?? variables.find(variable => variable.name === 'ColorofLights');
temperature = readPercent(color, 'LightColor');
if (hasBrightnessLights) {
const dim = variables.find(variable => variable.name === 'LightBrightness');
brightness = readPercent(dim, 'LightBrightness');
} catch (error) {
log(`Warning: Could not read light settings: ${error.message ?? error}`);
for (const light of lights) {
if (light.capabilitiesObj.onoff.value !== turnOn) {
try {
await light.setCapabilityValue('onoff', turnOn);
} catch (error) {
log(`Warning: Could not switch ${light.name}: ${error.message ?? error}`);
continue;
if (brightness !== undefined && canSetBrightness(light)) {
try {
await light.setCapabilityValue('dim', brightness);
} catch (error) {
log(`Warning: Could not set brightness for ${light.name}: ${error.message ?? error}`);
if (temperature === undefined || !light.capabilities.includes('light_temperature')) continue;
try {
if (light.capabilities.includes('light_mode') && light.capabilitiesObj.light_mode?.value === 'color') {
await light.setCapabilityValue('light_mode', 'temperature');
await light.setCapabilityValue('light_temperature', temperature);
} catch (error) {
log(`Warning: Could not set color temperature for ${light.name}: ${error.message ?? error}`);
return true;
Please format the code part as code.
