Timeline alert “Zigbee has been restored” since upgrade to SHS 13.5.0
I’ve had a history of Zigbee issues but this one is new, I have SHS 13.5.1 and Zigbee runs on the Homey Bridge. I’ve just upgraded SHS to 13.5.1 this morning and the error happened again after. I had 13.5.0 which has been exhibiting this exact same behavior since I upgraded to 13.5.0 and is still with 13.5.1
I don’t see a question: Do you encounter any (new) zigbee issue, or is the notification just bothering you?
I also had that notification once on my Pro 2019. Didn’t notice any issues with the Zigbee network, unless you’re encountering issues you can just ignore it
The zigbee just dies now for absolutely no good reason, zigbee which worked all the time in SHS versions prior to 13.5.0, now it randomly dies and all zigbee devicesneed to be powered off and restarted for them to start working again. Happened today within a few hours of upgrading 13.5.0 to 13.5.1, before it would happen every 1-2-3 days randomly. At first I didn’t understand why it happened but yeah it seems to be an older bug (it’s referenced some years back with Homey) that resurfaced or is similar.
Yes I saw this error in olden times on the forum, but ziggbee becomes completely unresponsive after this error pops up now.
The typical Athom update debacle. - I haven´t updated for over a year now and everything is running fine. So I strongly recommend to turn auto update off and stay away from updates once you have a working setup.
I have the same issue since 13.5. Nothing works with any sense of timing. Sometimes it works. sometimes it doesn’t. It’s lika a lottery
UPDATE for 13.5.3
Same bug, also crashes randomly and won’t comeback until zigbee devices are rebooted, maybe it’ll be fixed one day.
