Timed Triggers
Yes, “Early Work Night” flow sets Work Mode to 2 and “Work Night” flow sets Work Mode to 1, but that’s it.
I have separate flows to do this so I could give a command to my smart speaker to trigger each 1 individually.
That’s it. Thank you for the suggestion of the Heimdal app, I will check it out!
Perhaps I did not catch it in the previous posts, but you have 3 message in that part of the flow that start at 7:10, which one (or ones) do you receive when the flows runs automatically ?
So I changed it up a bit but it still doesn’t work, but to answer your question it stops at step 3, but school variable is NO
One thing you could add to your step 3 message (if I understood you correctly this is the last message you receive) is to show the value of the variable “school_day”. This way you see in your message if the variable is set to yes or no before it reaches the logic card . Just to be sure Homey sees what you think it should see at that time, which should be “no”.
