TileDash - an Homey dashboard
Hello everyone, it’s been a while since I’ve been working to find a solution for a customizable Homey dashboard, and I’m happy to show you TileDash!
TileDash is a combination of TileBoard, which inspired me a lot, a project by Alexaï, and HomeyDash, for which I used the connection and communication method with Homey, developed by @Rocodamelshekima and @DaneedeKruyff
Thank you to them for their sharing.
TileDash works locally, you can customize it as you want to create your own dashboard!
I still have several things to configure, but I’ll share it with you as soon as possible.
I hope you’ll enjoy this little gift, wishing you a Merry Christmas!
EDIT 19/01/2023: v0.3 available, TileDash tool available
Enregistrement de l’écran 2023-12-24 à 05.40.19
In the early day’s of homey I wanted a screen to control my home. But until this day I only have my phone. The question is: how many times I’m going to use the screen if I have my phone.
I will follow your project. And maybe some day…
TileDash is available here!
Try it, give me your feedback!
V0.2 is available:
  • Now fits the smartphone: add mobile=true in url like http://YOUR_URL/?mobile=true&token=…
  • Adjust “portrait” orientation
  • Updated THERMOSTAT type
  • Updated SLIDER type and display value fixed
  • It is now possible to add the same device several times
  • The popup closes automatically after 20 seconds of inactivity (tell me if you want to custom this time)
  • Setting an id for the IMAGE type is no longer necessary
I’m also trying to:
  • create file/site to generate user dashboard’s file for easy configuration. (searching a solution…)
  • create tutorial for installation
Thermostat2
If you have not server, you can aslo run it locally on your computer:
  • Download TileDash
  • Open the TileDash folder
  • Right click on index.html → open with (select your browser)
  • In web browser tab, add your token like this:
I add a dashboard-DEMO.js file.
If you want to try TilDash, you can rename this file to “dashboard.js” and replace original “dashboard.js” file.
v0.3 is available
  • Add second value for SENSOR
    sensor
TileDash tool is available to create your configuration easily.
Upload a config to modify it is now available on TileDash tool.
Great job according to me ! Just what i’ve been waiting for … not so long since I’ve bought my Homey just a week ago… I’m on eedomus for now (I’m French)
I’ve just tried TileDash, but seems not find its way to my Homey …
Got this message in Chome console : athom-api.min.js:1
GET http://homey-myID*.local/api/manager/system/ping?id=myID net::ERR_NAME_NOT_RESOLVED
I guess the adress should be
https ://my.homey.app/homeys/myID*/api/manager/system/ping?id=myID
I’ve got a Homey Pro 2023, peharps it’s the reason why.
Could you tell me how and where to fix this ? (I can edit some of the .js files…)
v0.4 is available
Reease notes for v0.4
  • Flows and Advanced flows can be add on header (set them at end of dashboard.js)
  • Add possibility to disable screenSaver on mobile
  • Refresh the page when it comes back to the foreground on mobile
Gif flow mobile
This looks really promising! Learning curve is a little bit steep, but it doesn’t seem to be very long, so I’ll cope. I just have to decide what I want to display and how to do it. :smiley:
This looks great!
I tried installing this (v0.4) on my webserver so it’s accesible via the web. But I can’t get it to work with my Homey 2016 - 2019. I added the token, but somehow it can’t find the site properly. Without the token (url ending with index.html) it finds a site, but it is all black, but with a tiledash icon on the tab. With the token I get a 404, can’t find page. I tried replacing the dashboard.js with the demo version, but that didn’t help. What am I doing wrong?
Furthermore the Tiledashtool link isn’t working (https://tiledash-tool.000webhostapp.com/)
(image of site without token)
I have reinstall my TileDash because i have change my NAS, and it works for me, even with dashboard.js demo file.
Is your URL correct? Like:
http://server_IP/path_to_TileDash/index.html?token=xxx_your_token
Thanks for TileDash tool website, i will show that.
I found the Problem. Thanks.
There was a slash that shouldnt be there after the index.html.
If you could get the link to the tool working, that would be great!
Thanks a lot!
