Third Reality
thank you for your application for homey.
There is no dedicated page to exchange about the application, so I create one.
Concerning the multi-function night light sensor, would it be possible to create a flashing function in the application? (for x seconds or x minutes)
This could be very useful to visually signal an event in a noisy room for example.
Thank you in advance for your feedback
Since the app developer has not created a forum topic, it may be that they are not following the forum. You may need to contact the app developer from the app store.
For this app, the Contact -link takes you to the developer’s Github where you can submit a request.
Those that use TR light bulbs, in the devices page in Homey when I set my bulb to let’s say green shouldn’t the light indicator show green? Instead it shows it as white. I have some string lights when I change there color it shows as that color.
If you need the developer to look at it, please read the post right above yours.
Before I hit up the developer I just want to make sure this is how it is for others using third reality bulbs that it does not show color of bulb changed to.
Oh, I believe this can’t happen on one particular Homey, because it’s not a user setting, or a result of doing something wrong.
I just think you should notify the dev :wink:
Not sure if this is a Homey issue or a Third Reality issue. I have a TR matter nightlight that shows the color each time I change it.
I’ve read about a particular Hue light which shows the same ‘wrong’ color indicator.
As I see it, when it was a Homey bug, it would occur with any color light, for everyone.
Has nayone had any issues with the Third Reality bulbs working today? Mine are saying “Missing Capability Listener” every time I try to control any of my bulbs in the Homey app. I noticed in the TR Homey app changelog that an update was done today. Before I pull my hair out or throw these bulbs in the trash, I wanted to check here.
If: Matter protocol
and
If: Pro 2023/Mini/2026
You can update to the beta firmware, or better wait for the stable version to be published:
I appreciate it but I’m not sure if that helps me. I’m running the TR bulbs via Zigbee and the TR Homey app, not matter. At this point, I have moved them over to my Home Assistant and patched them back in to Homey via the HA Homey app. Seems to have fixed it….for now.
Also issues here. Homey updated thirdreallity app to v1.0.18. since then all thirdreallity motion sensor devices stopped communicating motion with homey Pro 2023.
Yes and I reported to TR bulb issue. GitHub · Where software is built
Same here. All of my Third Reality sensors stopped working since the Third Reality app updated. Tried to repair. Tried to factory reset and pair fresh. Nothing is working.
@DIYSHGuy @Maarten_Rensen
https://github.com/hwzolin/com.thirdreality.app/issues
