There is an APP (myIO)… If I have one myIO server (IP address, port, username, and password) it working well… But what if I have two, or more myIO server? There is a way to use more instance of the app, with different parameters or what is the way to solve this problem?
You can’t have two instances of an app running, so the only way is if the app is written to connect to multiple servers.
If you have the source code, you could change the app id. Then if you install the app via cli you have a second app instance.
But what Adrian said is better imo.
