Start scene on double click of a button?
I have an Aqara mini wireless switch which I want to build in an existing Gira wall switch.
Is there a flow for enabling the double-click action? It looks like Homey only supports the single click action so I was wondering if it I can make a flow which triggers scenes based on the number of clicks?
Regards,
Bart
Select Aqara scene activation to trigger the scene. there you can chose between single, double click or long press of button.
When you choose the device as a trigger in the When column, you should choose the “A scene is activated” (sorry for the Dutch language in the examples )
then you can make a choice, by clicking the field, for how many pushes you want for this flow:
Yes works like a charm! Thanx!
