Start an advanced flow from a virtual button?
As above, Is it possible to start an advanced flow from a virtual button press?
Thanks
In your advanced flow, right click (or Add at the top left) and add ‘start’
This will create you a little play button that can be used to start this flow
Is that what you mean?
Yes, use the ‘Pressed’ WHEN/trigger card of the virtual button device:
Thanks Both,
I completely missed the option of adding a start button to the start of the advanced flow and that allowing me trigger it.
The virtual button switch also works perfectly.
