[Sponsored][Review] THIRDREALITY A10 Smart Air Quality Sensor – Real-World Testing with Homey Pro
Disclosure: THIRDREALITY provided this device free of charge as part of our product-testing collaboration. This review covers the commercially available model and is based on my personal experience and measurements collected through Homey Pro.
Introduction
As someone who actively uses more than 200 smart home devices, I have always been interested in indoor air quality monitoring.
I already own several air quality monitoring devices from IKEA, Netatmo, and Aqara, so I was particularly interested in seeing how the THIRDREALITY A10 would perform within my existing Homey environment.
Rather than simply introducing the product and its specifications, I wanted to evaluate its real-world performance, reliability, Homey integration, and measurement behavior.
Packaging and First Impressions
One of the first things that pleasantly surprised me was the packaging.
The box features a very simple, single-color design without unnecessary visual elements. However, from the moment I held it in my hands and started opening it, it reminded me of the experience of unboxing an Apple product.
Despite its simplicity, the packaging creates a surprisingly premium and satisfying first impression.
It is a small detail, but one that I genuinely appreciated.
Design and Power Supply
The A10 features a compact and minimalist design.
One particularly interesting design choice is the recessed USB-A connector on the back of the device.
The sensor can be powered directly from a compatible USB power source or through the included European wall adapter. This allows for a clean installation without unnecessary cables.
Another advantage is that the device is continuously powered, eliminating the need for battery replacements.
Technical Overview
Feature Specification
Model 3RAQ1096Z
Tested firmware 1.00.17
Communication Zigbee 3.0
CO₂ monitoring Yes
VOC Index monitoring Yes
Temperature Yes
Relative humidity Yes
Power supply USB
Battery required No
Zigbee role in Homey End Device
According to THIRDREALITY, the device uses Sensirion sensing components.
Homey Integration
I have been using the A10 with my Homey Pro (Early 2023), and the integration has been working extremely well.
All four main measurements are available directly within Homey:
  • CO₂ concentration (ppm)
  • VOC Index
  • Temperature (°C)
  • Relative humidity (%)
All four measurements are also available in Homey Insights, making it possible to monitor historical trends and analyze environmental changes throughout the day.
What I appreciate most is the overall reliability.
During my everyday use, I have not experienced a single disconnection or any other operational problem with the device.
It simply works, which is exactly what I expect from a smart home sensor.
Comparison with IKEA VINDSTYRKA
I already have several air quality sensors in my home, including:
  • IKEA VINDSTYRKA
  • Netatmo Healthy Home Coach
  • Netatmo Weather Station
  • Aqara TVOC Air Quality Monitor
This photograph shows the devices I own, not a simultaneous test setup.
For my initial measurement comparison, I focused on the IKEA VINDSTYRKA because both devices were operating in the same room.
I collected historical measurements through Homey Insights over a 24-hour period between November 21 and 22, 2026.
The comparison includes 288 timestamp-matched historical data points per measurement, at five-minute intervals.
Measurement THIRDREALITY A10 IKEA VINDSTYRKA
Average temperature 23.55°C 24.84°C
Average humidity 42.36% 41.22%
Minimum VOC Index 23 18
Maximum VOC Index 270 82
The THIRDREALITY A10 reported an average temperature approximately 1.29°C lower than the IKEA sensor, while relative humidity was approximately 1.14 percentage points higher.
The most interesting difference, however, was the VOC Index behavior.
The A10 showed considerably more variation throughout the observation period, while the IKEA sensor’s historical readings remained unchanged for extended periods.
From a Homey automation perspective, having a more dynamic measurement history is particularly interesting.
However, I would not conclude that one sensor is more accurate than the other without a calibrated reference instrument. Device placement, adaptive VOC algorithms, and reporting behavior may all influence these results.
CO₂ Monitoring – A Particularly Useful Feature
One of the main reasons I find the A10 interesting is its ability to monitor CO₂.
Unlike the IKEA VINDSTYRKA and Aqara TVOC Air Quality Monitor, the A10 provides CO₂ measurements in addition to VOC, temperature, and humidity.
During a separate 24-hour observation period, Homey Insights recorded the following CO₂ values:
CO₂ measurement Recorded value
Minimum Approximately 395 ppm
Maximum Approximately 2,055 ppm
Average Approximately 808 ppm
These historical readings illustrate how much reported CO₂ levels can change throughout the day.
This is particularly useful in a home office, where we can spend several hours working without noticing changes in ventilation.
IKEA VINDSTYRKA does offer PM2.5 monitoring, which the A10 does not. Therefore, the two products can also complement each other rather than necessarily replacing one another.
Homey Flow and Automation Possibilities
For me, the real value of a smart sensor comes from what it allows us to automate.
The THIRDREALITY Homey application provides measurement-change triggers for CO₂, VOC Index, temperature, and humidity.
Some practical Flow possibilities include:
  • Sending a notification when CO₂ exceeds 1,000 ppm.
  • Activating a ventilation system when CO₂ increases above a selected threshold.
  • Increasing an air purifier’s fan speed when the VOC Index rises, provided the purifier has suitable filtration.
  • Controlling a dehumidifier according to indoor humidity.
  • Combining air quality measurements with presence and window sensors.
These are examples of possible automations rather than claims that I have tested every scenario.
What Could Be Improved?
Although my overall experience has been excellent, there are a few additional features I would like to see in the future.
In particular, I would appreciate configurable measurement reporting intervals and temperature or humidity offsets directly within the Homey application.
THIRDREALITY already documents configurable reporting intervals for certain other platforms, so having similar flexibility in Homey would be a welcome addition.
I also noticed that the device is identified as a Zigbee End Device in Homey, despite being continuously powered.
It would be interesting to understand whether this is an intentional hardware or firmware design decision and whether a Zigbee Router implementation could be considered in a future hardware revision.
These are suggestions for further improvement, not operational problems that I have encountered.
What I Like
  • Excellent everyday reliability in my Homey setup.
  • Four useful environmental measurements in one compact device.
  • CO₂ monitoring.
  • Native Zigbee integration with Homey.
  • Historical measurements through Homey Insights.
  • Useful possibilities for Homey Flow automations.
  • Compact design and flexible USB power options.
  • No battery replacements.
  • Surprisingly pleasant packaging and unboxing experience.
Final Thoughts
My overall experience with the THIRDREALITY A10 has been extremely positive.
I already own several environmental monitoring devices, but the combination of CO₂, VOC Index, temperature, and humidity makes the A10 a particularly interesting addition to my Homey system.
Most importantly, I have not experienced any operational problems or connectivity issues during my everyday use.
I will continue evaluating its measurements and comparing its behavior with other sensors in my home, particularly my Netatmo devices.
For Homey users looking for a compact Zigbee air quality sensor with CO₂ monitoring and useful automation possibilities, the THIRDREALITY A10 is definitely worth considering.
I would also like to thank the THIRDREALITY team for providing the device and giving me the opportunity to evaluate it.
Official product page:
https://www.thirdreality.com/products/smart-air-quality-sensor
THIRDREALITY Homey application:
I would be interested to hear about the experiences of other Homey users who are using this device or other air quality monitoring solutions.
Are you sure that it’s commercially available? I don’t see the sensor on Amazon and it’s missing from Third Reality’s mobile app
smarthomesven
It is listed on THIRDREALITY’s official online store for $49.99:
However, I’m not sure about its availability on Amazon. Regarding the THIRDREALITY mobile app, I haven’t tested it, as I’m using the sensor directly with Homey Pro.
