after reinstalling three times the lamp goes out every time with error message time out after 10,000 milliseconds
what can i do about this?
This is very little info to work with.
What did you install 3 times?
Sonoff is not a lamp? Is the problem with the lamp or with the Sonoff?
Minr4m is not mentioned as supported device, what is it? Can’t find it anywhere?
What protocol is used by the Sonoff and by the lamp?
Which Homey model & firmware?
Which app(s)?
Thanks
I have a Sonoff Mini Extreme MINIR4M (best buy guide Switch Modules). I have placed it between a lamp, so that I can also switch it with a normal switch. I have installed it with Mater protocol, where it also works (wall switch and via the Homey app) I have also created a flow with a motion sensor (also tested and working) but after a while the error message timeout after 10000ms
I have the Homey Pro (Early 2023), 12.1. 2
I hope you can help me.
thanks in advance
Ah, a Matter device. Which doesn’t need an app.
I’ve read more posts about Matter instability, the best option is to report the issue to Support | Homey, as I think there’s no workarounds or things you can do yourself.
Thank you, then I will try that.
