Somfy Tahoma App Error 400 - Pergola Percentage slider has no function anymore ?!?!?!?!
was shocked today to discover that my Somfy awnings can no longer be controlled properly through the Homey app.
It seems that an update has broken everything. I keep getting Error 400.
After many restarts and even reinstalling the app, nothing changed. By chance I pressed Down and Up, and surprisingly the awning still moves up and down. However, the percentage slider no longer works.
This is unacceptable. A few months ago everything was working perfectly.
I have a Somfy Connectivity Kit and 2 awnings / pergolas.
What can I do to get the percentage slider working again? Anything else is not an acceptable solution for me.
Is there perhaps an older app version that still works? If so, how can I install it?
Does nobody else have the same problem?
Everything works perfectly through the Somfy TaHoma app on my phone.
3 posts were merged into an existing topic: [APP][Cloud & Pro] Somfy Tahoma & Connexoon (v4.0.106, test v4.0.122)
