Somfy light switches
@Adrian_Rockall,
Since the last update, 2.1.52, the switches no longer work properly.
I have to restart the App “Somfy TaHoma & Connexoon” for every action and can then perform just 1 action.
Has anything changed?
Can you install the test version as that should fix it.
@Adrian_Rockall,
Looks like 2.1.53 fixes it.
I’ll keep an eye on it.
Thanks for the quick response.
@Adrian_Rockall
I tested it for a few days. It seems to work as usual.
Hello Adrian,
After today’s update, the connection to Tahoma has been lost.
The credentials are good.
I have restarted the app.
I have restarted the Homey.
None of it helps.
I just sent you a log.
The unique code is 18fbabf2-c558-4544-b0e1-6f27771844f8
Can you tell me what’s wrong?
The error 401 code seems to be quite common lately. So far I think they have eventually solved themselves. I’m not sure why the servers reject the login sometimes.
It looks like it has resolved itself.
I was able to reconnect tonight.
Thanks for the reply.
