I’m running SoLyX Energy Nymo system with Homey Pro, but I’m having trouble keeping it from pulling energy from the grid when heating on excess sun. Whatever flow I set up, it seems to still use grid power. Even one of the flows suggested by SoLyX online is still pulling extra power from the grid.
If I use the supplied SoLyX P1 sensor, it works fine—it’s only then using my exported energy that my solar panels are creating, as it should.
Here is the tricky part: because the system is connected to the SoLyX P1 sensor, it can’t be connected to my Homey Pro at the same time, as it only allows one sensor connection. This means other flows I’ve made, like hot water boost or time delays, will not work because the system isn’t connected to the Homey Pro. I’m trying to see if anyone has a flow that only uses the exported energy without relying directly on that sensor? Any help or advice would be greatly appreciated!"
