Shelly Pro 3EM false energy readings
Has anyone else observed following? The Shelly Pro 3EM energy measurement device reports buggy values to Homey. From Shelly’s app everything seems to be normal, but in Homey the “Energy” parameter fluctuates between kWh and Wh. That is, the device shows occasionally 1000-folds too big values. Attached is an Insights plot from the device. The same erroneous fluctuation occurs with the two other Homey Devices of that same Pro 3EM.
The Total Energy -parameter that sums up the three Energy-readings seems to work properly. But for some reason I am unable to use that value in e.g. Power by the Hour -app.
Another thing related to the same device: It seems to be impossible to configure the Shelly Pro 3EM as the smart meter of the whole home. This renders the Energy -section of the Homey unusable. Does anyone know a workaround for this?
First of all, welcome to the Homey Community!
To make sure you are aware of the forum rules, please read the Welcome to the forum post here.
Example:
Rule #7: Don’t reply to your own posts in the same topic but edit your previous post.
Also please use search and ask in the appropriate topic, as linked in the App store or use the search to centralize questions about a specific App of device/brand.
[APP][Pro&Cloud] Shelly
Therefore, your posts will be moved to the appropriate topic and this topic will be closed.
If you have any problems with that please feel free to contact me or another moderator.
