The Shelly Plus 1PM with the add-on device placed on it is able to handle 5x temperature-sensors…
In Homey Pro the sensors are named in the follow way:
- Temperature-sensor 1
- Temperature-sensor 2
- Temperature-sensor 3
Instead of numbering up to 4 and 5, it gives a basic name without a number… Ok, it is possible to use it in a flow, but it is always the big question wich one is 4 or 5… Just try it a few times and you find the correct temp.device.
Would it be possible to fix this issue in a next update? Even more great would be, when the defined sensorname from Shelly-cloud/device would be there instead of a number!
Thanks anyway for reading this!
Best regards,
Mark Kobes
