Scaling
I have an Aqara FP2, an Everything Presence EP1, and another 4 in 1 Zooz sensor.
My issue is, the light sensors in all of these devices aren’t the most accurate, and I haven’t found a good stand alone light sensors (let me know if you know of 1).
I want to be able to build a scale like you would do with industrial automation to correct the light sensors. i.e.
When the EP1 shows illuminance of 0, that would be 25, and when it reads 4 = 50, and 10 = 100. As you can see, a simple offset will not work, because it would have to be different for every number.
With industrial automation, you could set a scale by setting the lowest number “0” to “X” and the highest to “X” i.e. 500 - 6553 would be 0 - 100, or in my case 4 - 10, would be 25 - 100. and it would just automatically increment accordingly
