Safari: Flow card dropdown menus invisible when accessing Homey via my.homey.app
Anyone else experiencing problems getting the flow-card drop-down menus to appear in Safari?
Product: Homey Pro
Browser: Safari
Platform: macOS
Access method: https://my.homey.app
Summary
Dropdown menus in the Flow editor briefly appear and then disappear when using Safari through the cloud portal. The menu options are still logically present (they can be selected via keyboard), but they are not visible.
Steps to reproduce
  1. Open Safari on macOS.
  2. Log into Homey via https://my.homey.app.
  3. Open the Flow editor.
  4. Add or edit a Flow card with a dropdown selector (e.g., an Alexa device card).
  5. Click the dropdown arrow.
Observed behaviour
  • The dropdown flashes briefly and disappears.
  • The menu items are not visible.
  • However, typing the first letter of an option still selects it (e.g. “A” selects “Announce”, “S” selects “Speech”).
  • This indicates the dropdown is active but not being rendered visibly.
Expected behaviour
The dropdown menu should remain visible and allow selection of options.
Additional observations
  • The issue does not occur when accessing the same Homey locally via its LAN address (e.g. http://192.168.x.x).
  • The issue also does not occur when using Microsoft Edge.
  • Clearing Safari cache, disabling extensions, and using a Private window did not change the behaviour.
Conclusion
This appears to be a Safari-specific rendering issue related to the UI when accessed through my.homey.app. The same interface renders correctly when served locally by the Homey device.
Possible hint
The dropdown remains keyboard-accessible even when invisible, suggesting a Safari issue with rendering a floating overlay element (possibly a z-index or iframe compositing issue) in the cloud portal interface.
Have the same
Hier ook hetzelfde probleem
Good to know that it’s not just me, and that this is a wider problem. I guess since only 2 people have commented, that not many people use Safari browsers with Homey, or they have just used a workaround.
I submitted a ticket on the issue. They asked me to clear the cache, but that didn’t solve it. Hope they come back with a solution later.
Arrow down will let you pick a value. Not okay but workable. Only a Safari issue, Firefox works well also.
Same for me since a week. Arrow down is working but…
This should be fixed.
The problem is still there
