Run a remote script
I want a flow that triggers an external script( on a raspberry pi). But the ssh app doesn’t work. Is there any other way to do this?
Maybe sending a webhook would be a solution
thanks for your reply. How do I put a ssh command in a webhook?
well, you would first of all need to run a webserver or a nodejs http listener to consume the webhook and then pass the payload on as a ssh command on your target system.
I do wonder why the ssh approach does not work though.
Because the ssh app is hardcoded to only work on firmware 0 and 1 (although it looks like it will run on v3, and likely v4, just fine if you change the compatibility in app.json and CLI-install the app: v3 compatibility? · Issue #6 · kerkenit/nl.marcovantklooster.sshclient · GitHub)
I installed the SSH app with the CLI-Method. I thougt it wasn’t working because of the incompatible version. But it worked. Thanks all.
