Run a flow only once
I have several flows that ask for confirmation. For example if its 27 degrees homey asks if i want to put on the airco. Now i want him to ask this only once a day. Is that even possible? Looked for an existing answer with the search option but no luck.
greetz Frans
THEN put on the airco AND disable the flow.
Make an extra flow to enable the flow again at any time u like.
Hm, so simple why didn’t I see this. Thank you very much. I can do a lot more again.
Greetz Frans
you could also use a virtual thermostat for controlling your airco !! https://apps.athom.com/app/no.almli.thermostat
