Rollershutters no longer operational in google assistant
Since recently, some of my roller shutters are no longer operated from within Google home .
Upto 2 weeks ago: Hey google, put all shutters to 50% → 5 shutters start moving
Now: Hey google, put all shutters to 50% → 1 moves (FGR-222), 4 do not (FGR_223)
Bug Report – Fibaro Roller Shutter 3 devices are no longer controllable in Google H ome
Environment
  • Homey Pro (Early 2023)
  • Homey firmware: 13.3.0
  • Fibaro app: 3.8.7
  • Google Home
  • Google Nest Mini
  • Google Nest Audio
  • Google Gemini enabled on Android p hone
Devices
Working
  • 1 × Fibaro Roller Shutter 2 (FGR-222)
Not working
  • 4 × Fibaro Roller Shutter 3 (FGR-223)
All devices are configured as Sunshade in Homey and have been successfully calibr ated.
Descr iption
All Roller Shutters work perfectly in Homey.
After synchronizing with Goog le Home:
  • All devices are imported.
  • In Google Home All devices; have device typ e Blinds.
  • In Google Home All devices; Manufacturer is shown as Homey.
  • In Google Home All devices; Connected via Homey.
However:
  • The FGR-222 opens a control screen in Google Home with Up and Down buttons and is fully c ontrollable.
  • The FGR-223 devices open only the information page. There are no Up/Down buttons and no pos ition slider.
  • Voice control no longer works for the FGR-223 devices from:
    • Google Home app
    • Google Nest Mini
    • Google Nest Audio
Expected behaviour
All Roller Shutter devices should expose the same controls in Google Home and should be control lable by voice.
Actual behaviour
Only the FGR-222 is treated as a co ntrollable blind.
The FGR-223 devices are recognised as blinds but Google Home does not ex pose any controls.
Troubleshooting already performed
  • Updated Homey to firmware 13.3.0.
  • Updated Fibaro app to 3.8.7.
  • Removed Homey integratio n from Google Home.
  • Linked Homey again.
  • Executed “Sync my devices”.
  • Enabled Google synch ronization in Homey.
  • Waited for synchro nization to complete.
  • Verified all Roller Shutter 3 d evices are calibrated.
  • Verified all Roller Shutter 2 and Roller Shutter 3 devices are configured as Sunshade.
  • Verified all devices work correctly inside Homey.
  • Verified Google Home identifi es all devices as Blinds.
None of these st eps changed the behaviour.
D ev eloper T o ols obser vations
FGR-222
Driver:
  • com.fibaro:FGR-222
Capabilities include:
  • dim
  • windowcoverings_state
FGR-223
Driver:
  • com.fibaro:FGR-223
  • dim
  • measure_power
  • meter_power
The FGR-223 does not expose windowcoveri ngs_state, unlike the FGR-222.
I do not know whether this difference is intentional, but it appears to correlate with Google Home exposing controls for the FGR-222 while not exp os in g controls for the FGR-223 .
Additional observations
This exact setup worked correctly in Google Home in the past. (Hey google, put all blinds to 50% worked for all, now only for my 1 FGR-222 device)
The problem appeared after the r ecent Google Home / Gemini changes.
The FGR-223 devices are still fully controllable from Homey itself, so the issue only af fe c ts the Goo gle Home integration.
Question
Could you verify whether the Google Home integration is exporting the FGR-223 with the correct Google device traits and capabilities?
Since the FGR-222 and FGR-223 behave differently in Google Home despite both being configured as window coverings in Homey, this may indicate a regression in the Google Home export or a compatibility issu e wi th the current Google Home platform.
I think you should report that to Athom, since they are the developer of the Fibaro app
Have you tried it yourself. I have been there. I keep getting forwarded to this forum.
They start looking like KPN and Microsoft
I have no idea where to actually contact them.
Even an email to supprort@… Gave me a reply. This is not the correct way to start a topic. Your issue is not being handled this way.
If you can’t create a support ticket, you just need to select “My Homey isn’t listed” at their support page and then you can create a ticket
That was a great tip! Thanks
As expected Athom just says. Not our problem, go fetch with Google.
I even pointed them to a possible solution, but hey, why make an effort to fix it from your side if your could also lay it with someone else.
Well, it’s an issue in their Fibaro app. The dim capability shouldn’t be used for this, they should use windowcoverings_set. Dim is only for lights.
So you should just create another ticket​:wink:
Something is probably different at you end, as I have only FGR-223 and all are shown like this in a Google Home :
Naturally don’t forget to set this property as well
