Ring door bell Elite
Hi All,
Has anyone had any success in using the motion detection from the ring doorbell elite to trigger a light to turn on ( in my case a hue lamp)
I’ve created the flow using the ring app, when I press test it turns on the light but when i save it will just not work at all. Motion is detected but the light doesn’t turn on.
My flow is
When doorbell motion turns on
And it’s nighttime
Then turn on hue lamp
Then turn off hue lamp after 2 minutes
Was hoping to be able to make use of the motion alert instead of having to put a separate motion sensor there.
Thanks
Chris
