[Request] RTSP(S) Cam live stream support
Thanks @Doekse for the swift and honest reply as always mate, much appreciated.
I though as much as Wyze as a company well it’s been plain stubborn for … ages … it feels.
Outside of that scope; can you perhaps ask internally if someone can look at what I think might be some codec issues with displaying the V4s RTSP stream. Having them as a virtual camera like this is still valuable for me and I presume a lot of people.
If I can help in any way with that further, feel free to let me know, I have 7 v4s around the house. (which all work through flows more or less thanks to some Shelly plugs)
Thanks again for all your time and effort!
You can check media information in VLC (Command-I on macOS, don’t know about other platforms), so you can find out the differences between each model.
I’m suspecting it might have something to do with go2RTC in this case. Best would be to create a support ticket, my colleagues can help you out here.
Ill check that out in a few an post the info here just in case.
Thanks for the suggestion @robertklep
EDIT:
V4 - Not working in Homey
Stream 0
Codec MPEG AAC Audio (mp4a)
Type Audio
Sample rate 16000 Hz
Decoded format 32 bits float LE (f32l)
Decoded channels Stereo
Decoded sample rate 32000 Hz
Decoded bits per sample 32
Stream 1
Codec H264 - MPEG-4 AVC (part 10) (h2…
Type Video
Video resolution 2560x1440
Buffer dimensions 2560×1440
Frame rate 20
Decoded format CVPN
Orientation Top left
Color primaries ITU-R BT.709
Color transfer function ITU-R BT.709
Color space ITU-R BT.709 Range
Chroma location Left
V3 - Working in Homey
Stream O
Codec PCM ALAW (alaw)
Type Audio
Sample rate 8000 Hz
Bits per sample 8
Decoded format PCM S16 LE (s16l)
Decoded channels Mono
Decoded bits per sample 16
Stream 1
Type Video
Video resolution 1920x1080
Buffer dimensions 1920x1088
Frame rate 20
Decoded format CVPN
@Doekse thanks again for the swift reply. Will do so :slight_smile: thanks for being awesome as always!
Other than the resolution there doesn’t seem to be a lot different between the two video streams.
Agreed, have a ticket open with support, and we are going back and forth on things.
Once we get somewhere ill update about it here.
Just to update you all, ticket was closed. Team knows but sadly I think it simply does nat have the highest priority as noted by others before. Really a shame as you can get the same RTSP links working on various solutions…
