I do understand and respect your standpoint on apps that require full access to Homey to do what they do. To add to that, the code of Heimdall is open source and I invite everybody with second thoughts to review the code at GitHub - daneedk/com.uc.heimdall: Heimdall for Homey
Hello everyone, I wrote a script for get zonename by device.zone.
Script:
//get zone name
async function getZoneName(zoneId) {
var result = “unknown”;
let allZones = await Homey.zones.getZones();for (let zone in allZones) { if ( allZones[zone].id == zoneId ) { result = allZones[zone].name; } }; return result; }
And you can call it:
return getZoneName(device.zone);
or part of string
… + await getZoneName(device.zone) + …
Now where have I seen that before… ![]()
Thank you for the nice script. Could you also write it without ‘(undefined)’ behind each sensor? This way, I can have a notification triggered through a speaker
Hi peter
thanks for the script, i just found it here, but im kinda new to homey and the script are working very well, just want to know how i can ge the output from it into a push message to a user i pick, hope you can help thanks
Thank @RonnyW ![]()
You can use the used Homeyscript tag/variable for those cases;
It’s created/updated in this line of the script:
// Create / update HomeyScript variabele
await tag("door_windowText", windowText);
Just select it to add it to any messaging card:
For advanced flow
You can use the adv. flowcard THEN "Run code and return Text-tag¨, when you change
this
return (true);
into this
return (windowText);
Like:
The available output tag “Result”, can be used in a messaging card
Thank you so much! appreciate you help very much!
