Hi everyone! I have a garage door that opens and closes with a Zigbee NodOn SIN-4-1-20 (1-Relay) module. As there is no setting to let this module pulsate, I’ve created a simple flow : “If switched on, than switch off in 2 seconds.”
For some reason, when creating this flow, this works 2 or 3 times and then it stops working and the tile of the device stays “on” (so I have to click twice the next time I want to use it). I had the same issue with a Fibaro Smart Module. No difference if I use an Advanced Flow or a regular one.
Somebody has a solution for me or a workaround?
Thanks in advance!
Regards,
Marc
