Refreshing content of web widget
I’d like to see a parameter in the web widget to set the refresh interval. As it is now, it is static. I’ve seen workarounds where someone has created a local webpage to solve that, but I think that is a bit cumbersome. I use it for showing the weather forecast of the current day using the Norwegian Yr service. It’s not so interesting to look at the weather forecast from the past.
Thanks
That’s a great suggestion!
Totally agree. I would like to monitor my Solar production in the web interface but the widget also just shows older values.
This has been added recently, by the way.
I have been unable to find this Automatic Refresh setting. Where is it located? Thank you.
Hi Greg.
Found it already?
No. I see no reference to an app name in the previous queries. What app contains that setting?
You can find it in the dashboard widget settings.
I finally found it in the Homey web widget. Thank you.
