Trying to move my Homey Pro to another house.
Turned it upside down, but the lights continue to be rainbow.
Trying to add a new device doesn’t find it either.
Any thoughts, or just a hardware issue that requires a return?
Thanks!
Thanks!
Let me just Google that for you:
Setup mode for Homey Pro 2023 does not involve turning it upside down (except to access the pin hole).
Good to know the automation community for Homey is just as smarmy as it has been back to the X-10 days.
If the Homey folks end up finding this, please don’t send Homey Pro 2023 customers to the support for “Homey Pro” (not 2023) instructions within your own app.
Would also be good to mark older support docs as (pre 2023). There is no way for a new user to know that this page doesn’t apply to the “Homey Pro” they just purchased.
I have a similar problem wanting to reset my new Homey Pro 2023.
Yes, i found the pin hole to insert something and press for 30 seconds, but nothing happens ![]()
Its hard to detect if i’m actually found the switch or just stabbing homey.
And its a very smal and deep hole so hard to find something smart to use for resetting.
So what do you use and how do you detect that the switch is pressed down?
I’m probably not the only one struggling with this, so if you have som advice, please share. ![]()
Like a paperclip?
The button is quite noticeable, if you press it correctly you will feel and hear it.
Thanks for your quick respond,
Where is a paperclip when you need one ![]()
I used a very smal screwdriver in the end. And yes this time felt and heard pressing the switch.
Resetting done and Homey is returning to life.
