Raised bed including garage for robomower and irrigation control
Planning :
Building up a raised bed with a compartment for irrigation control / electricity and a garage for the robomower.
Ausstattung:
  • Irrigation control should be easily accessible. You don’t get younger, so no dislocation of any body parts needed during working :slight_smile:
  • Robomower charging station (Gardena R40i) has to be included
  • Sight protection, so everybody outside couldn’t watch and entrance should be closeable because of weather → installation of an electrical blind
  • Power supply for
    • solenoid valve
    • Blind
    • Lighting
    • Osram Gardenspots
    • 2x Reserve
Parts:
  • DYI timber work or buy a Karibu Hochbeet “2” 173x82x89 (maybe only available in Germany)
  • 5x solenoid valve Hunter 24V 101 NC
  • Transformator 24V
  • Water Distribution (Rainbird)
    • 1: Sprinklers (three) South
    • 2: Sprinklers (two) West
    • 3: Hedge Gardena Microdrip
    • 4: Terrace Gardena Microdrip
    • 5: Raised bed Gardena Microdrip
  • 3x Fibaro 222 Switch
  • 3x Gardena Microdrip System
  • 2x Lawn with Rain Bird sprinklers
  • electrical blind incl
  • Qubino Shutter Z-Wave Module
  • LED lighting for robomower
  • moisture proof equipment for electrical wiring
  • parts for canopy
  • Pond liner 0.5mm
Contruction
  • Foundation (Grit and conctrete panels) :white_check_mark:
  • Substructure :white_check_mark:
  • Superstructure :white_check_mark:
  • Installation electrical equipment (tbd)
  • Installation robomower charging platform :white_check_mark:
  • Installation blind :white_check_mark:
  • Installation lighting (tbd)
  • Installation irrigation (tbd)
Links:
https://www.karibu-onlineshop.de/karibu-hochbeet-2-mit-schrankoption?attribute[garden_model]=naturbelassen
https://www.jalousiescout.de/
https://www.rainbird.de/produkte/versenkduesen/typenreihe-1800tm
Amazon Shopping Card if needed, please feel free to post below.
Substructure:
inlet and substructure
Installation Blind
Front closed + blind installed
Compartment irrigation and power supply
  • Distribution box installed on a wooden panel
  • electrical connections are on the side away from the water
not to bee seen:
  • partition wall between water and power distribution box
  • Panel for Mircodrip prefilter
Affixing of pond liner
  • should be a really warm day, so pond liner gets more flexible
  • try to be wrinkle-free :slight_smile:
  • sink as water outlet
  • i fixed the pond liner with a panel and small elbows
Filled up with soil and plants it looks like this:
It’s raining again:
Water distribution, valves below. On the upper left the fertiliser device for the raised bed and Microdrip prefilter.
First tought: the sprinklers cause pressure shocks at the system when moving up. Think the necessary pressure has to be reached.
So i will program both sprinkler circuits not one after the other. Instead i will take one circuit with the microdrip system inbetween.
Electrical wiring :
Not very nice at the moment :slight_smile: Installation with Wago terminals just for testing.
Will be rewired after testing.
Wiring diagram:
Update Automower: integrated head-/rear lights.
Not really necessary, but a nice to have :slight_smile:
The mower won’t drive during night time, so hedgehogs are still save.
Great @Tequila329! I will adapt some parts of your project.
Feel free to do so! :slight_smile:
Posted a small update:
  • water distribution
  • electrical wiring
  • mower upgrade
Add the wiring diagram for the Fibaro devices…
The plants love it :smile:
