Question for anyone using a Shelly Wall Display (XL or X2i)
Has anyone already updated to firmware 2.6 and can confirm whether there is now an App Store with Homey integration? If yes: How does it look, what can it do, and is it working reliably for you?
Thanks for checking!
Apps beim Shelly Walldisplay! Presence über Kopf? Seco HMI für Home Assistant? Aqara FP400 kommt …
Firmware 2.6 has been running quite stable and smooth for me so far. The Homey app (also the new Home Assistant App) from the Shelly Wall Display App Store (Wall Display XL) is not quite as fast as on a smartphone or tablet, but it still works perfectly fine. Basically, you can use everything just like you would on a phone or tablet.
Thanks for sharing your experience! I already have two of the regular Wall Displays and I’m now thinking about getting either the XL or the X2i as an upgrade. Your feedback about the performance on 2.6 is really helpful for that.
I’m currently using my own app, Shelly Wall Display Dashboard | Homey, on the smaller Wall Displays. It works by using the built‑in Home Assistant Integration on the Shelly Wall Display and serving a custom dashboard from a separate port on Homey.
Do you know if the Shelly Wall Display XL still allows this — meaning, can I open my dashboard in a regular browser or somehow else on the XL and continue using my app that way?
Thank you!
Andi
Your App is on a Shelly Walldisplay XL usable as wanted:
Installing the HA App from the app-store, entering the server adress in the app and just working fine.
Thank You!!!
I just bought it. I had to update it to 2.7, otherwise I did not know I could install the app itself. It works, the dashboards seem very slow but functional.
Did any of you use the integarted buttons?
