Qubino Dimmer 0-10V ZMNHVD don't dimm from app
hello. I’ve problem quith Qubino dimmer 0-10V for control a strip led bar.
If i change the dimm light with momentary swith, the value and the dimm is corrent change (i mesure the value in volt and corrent change from 0 to 10V).
In the app, if i move the slide bar to dimm the value, the action don’t effect.
Do you have this issue?
The app and homey is update.
Thanks
A better place to ask your “Qubino” question is:
Thanks for replay. I will follow this suggest
