I am a homey pro early 2023 user.
My question I can suddenly no longer control a large part of my devices via google assist.
I have removed google home and reinstalled it.
I have redone the google connection in homey several times.
Can someone help me on my way.
Thanks in advance
I think we need more info. Are all your devices showing up in the google home app?
yes they do
I have the Same problem please advise
So if I understand correctly: all your devices (google-devices and devices you have in Google Home because they are in Homey) you can see in Google-home.
The thing which is not working is within Google Home as you cannot control them with Google assistant. So voice-control is not working?
Is controlling them within Google Home working?
Anyway: it looks more like a problem with Google than with Homey (??)
In home I can control everything, but with voice control only a few work.
what does work partly is switching on the whole room.
most of the separate switches I only get google examples, for example a twilight lamp etc.
I deleted the house in home and created a new house-
It seems everything is working again.
I will check it thoroughly.
Thanks in advance for your responses.
I also removed the home.
But I still can’t connect to homey
Sorry due to circumstances I can’t answer quickly.
Has your problem been solved yet?
vlietmed
No still have the problem.
Have you re-paired Homey in Home?
Yes I get the error that home can’t connect to homey
Have you checked the link with Google in Homey?
Yes homey tells me to setup link in home
The question is, have you checked the integration with Google Assistant in Homey?
Otherwise the problem is in Google.
Maybe you can restart everything from the beginning.
Furthermore, I don’t know, maybe more people come from the forum.
/Vlietmed
Can you provide some more info on what your problem is. Also some more insights in what you already did and the text of the error message could help.
I have no more problems but since it has been solved for me.
But Goldstrike has not solved the same problem yet
/vlietmed
